Hello I am going to build a PC for the first time and I have a question. I want to use the Corsair RM650x 80+ Gold 650w power supply with the Fractal Design Meshify C ATX Mid tower case but I want to confirm that it will fit in the case and function without issue. Thanks
https://linustechtips.com/topic/1076013-casepower-supply-question/
You're good
It will fit. If you are worried, put them in pcpartpicker and check for incompatibility.
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
ATX case.  ATX power supply.
It'll work.
