overclock failed ram help
Solved by Skiiwee29,
5 minutes ago, wolfbytes2005 said:i umplugged it and held the cmos button for 10 seconds witch i read in the manuel
can you get into the BIOS? When you booted back up after the clear CMOS, did a screen pop up and warn you that all your settings were reverted back?
Edit: See you cant get it to post. Try removing the CMOS battery from the board for about 10 minutes.
