Differences between M.2 keys
Solved by TheSLSAMG,
There should be no issues running the drive on the board.
M.2 B+M key is commonly used for SATA and PCIe 3.0 x2 NVMe SSDs. Your board is keyed correctly and compatible with those drives. There are also drives that carry only M-key, but these are typically higher end PCIe 3.0 4x drives such as the Samsung 970 Evo Plus and Western Digital Black SN750. You can also run these drives.
