Hello!
I have just finished a pc build, and when I try to boot, my monitor reads "NO SIGNAL", but all the fans and RGB turns on.
I have a ASROCK p67 Extreme4 Gen3 Motherboard, and it reads error codes D6, D7, and A2.
Here's what I've tried:
New HDMI Cord
Different Monitor
Different VGA Cable for Graphics Card
Different Graphics Card
Checked Ram Slots
Made Sure CPU was Installed Correctly
Please Help!
https://linustechtips.com/topic/1075229-no-signal/
So, according to the manual
0xA2 = IDE detect
0xD6 = No Console Output Devices are found (some sort of graphics output)
0xD7 = No Console Input Devices are found (mouse/keyboard)
So, questions I have:
What are the full specs of your system?
Are you plugging into the graphics card or motherboard?
Has this monitor worked before?
Is it on the right input?
Do you have a mouse and keyboard connected?
Do you have an IDE device connected?
Are those the only codes you get?
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
https://linustechtips.com/topic/1075229-no-signal/#findComment-12665790
