Hey!
I have a Cat6 wall port thingy in my room and I’ve noticed that when I bearly touch the Ethernet cable that is connected to it, it disconnects whatever it is plugged into it. I have also noticed that my Ethernet has been cutting out randomly from the wall plug to my PC.
Could the Ethernet wall plug be damaged?
Also, even if it is damaged, why would It still work fine but then randomly cut out?
CPU: AMD Ryzen 7 3700X | Mobo: Asrock AB350 Pro4 | Ram: G.Skill Trident Z (2x8GB) DDR4-3200 | Storage: Intel 545s Series 256GB M.2 (SATA) SSD/Western Digital WD Blue 1TB/Samsung 860 EVO 500GB SSD | GPU: Zotac Geforce GTX 1060 6GB AMP! Edition | Case: NZXT S340 Black Case | PSU: Corsair HX750 | Operating System: Windows 11 Pro | Keyboard: Ducky One 2 Mini White MX Brown | Mouse: Logitech G Pro Wireless | Headphones: Astro A50 Gen 2 | Mic: Rode NT-USB | IEMS: KZ ZSN Pro X
https://linustechtips.com/topic/1073583-possible-port-failure/
Possible, yes. I would suspect a faulty cable before I suspected a faulty port, however. Try replacing the cable, see if you see any improvement.
Check your modem and/or router for any event logs, see if there's an issue with your connection dropping reported there.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1073583-possible-port-failure/#findComment-12651419
sounds like a bad port. Terminate a new one and try.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1073583-possible-port-failure/#findComment-12651455
Just a bit of an update:
There were a few bent pins in the port, just got a screwdriver and pushed them upwards and I guess that fixed it..?
So yeah, ty.
https://linustechtips.com/topic/1073583-possible-port-failure/#findComment-12653820
