I built the PC I have now at the end of 2017 and definitely made a few mistakes:
  • CPU
    Ryzen 1700x
  • Motherboard
    Asus X370 Crosshair VI Hero Wifi
  • RAM
    4 * 8 G.skill RGB DDR4 2933 Mhz
  • GPU
    EVGA GTX 1080Ti SC2
  • Case
    Fractal Design Meshify C
  • Storage
    Samsung 960 EVO 500GB
  • PSU
    EVGA 750w G3
  • Display(s)
    Dell SG2716DG +  2xDell U2515H
  • Cooling
    Corsair H100i V2
The SSD was definitely overkill and the memory I purchased wasn't B-Die, but otherwise it was a solid build. Going forward, what should I upgrade or replace? My graphics card is great but the 1700x does hold it back some, though it's less of an issue at 1440p. Would a Ryzen 3000 series chip be worth putting in this motherboard, considering it is X370? I'd like to get more out of my graphics card if possible. Are there any other upgrades that might make sense?
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
https://linustechtips.com/topic/1073213-future-thoughts-for-my-build/
Everything is good except your CPU.
This should be your priority for gaming (and fast) :)
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
It's hard to say without any benchmarks or tests with the new chips yet. You do have a high end board but I wouldn't really try out the new chips on that board until someone else does. The only upgrade I would consider is CPU/mobo maybe, everything else is completely fine.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
Yeah gaming is my only issue at times.
I'm wondering if it's even worth running a newer CPU on such an "old" board since XFR won't work quite right if I remember correctly.
PC Specs:
Freenas specs:
@Constantin
@zlolslavez
Or perhaps I could get a second 1080ti used on ebay. It'd give me a more solid fps in games like destiny 2 and fortnite (where I don't want to lose any fps at all) and would let me disable sli and use one dedicated for rendering.
PC Specs:
Freenas specs:
20 hours ago, ThatFlashCat said:
@Constantin
@zlolslavez
You'd be better off saving up and then seling your current 1080 ti for the 2080 ti.
Most games don't even support SLI and last time I checked I don't think anyone is going to anytime soon.
That being said the 1080 ti is still great. You'd be better off just upgrading your cpu and mobo. New Ryzen chips are coming out and even if you don't want to spend money for the new 3000 chips the price on the 2000 chips will, most likely, drop so you could see what the discounts are like and buy a 2700 and a x470 mobo comco at a microcenter for like $400-$500 and still have the option to upgrade to a 3000 chip down the line.
Yeah good point. Still though, my 1080 ti is definitely plenty for now, especially if I get a Ryzen 3000 chip. I'm considering getting the 12 core one, possibly with the same motherboard but I might also upgrade. About the RAM, though, it's not B-Die and it's 2933 Mhz, but perhaps Zen 2 cares less about memory than Zen 1. I love microcenter though!
PC Specs:
Freenas specs:
