F@H Multi-GPU Question
Go to solution Solved by tk421,
Yes you can. The cards don't need to be in SLI/Crossfire to do F@H, BOINC or mining. Because they're doing their own thing technically, and also not outputting an image.
Yes, you can add as many GPUs as your motherboard supports. F@H doesn't support sli/crossfire and looks at each GPU separately. This means you could have a GT 640, GTX 760, and an HD 7870 all in the same computer. Each gets assigned a separate work unit.
Thanks!
Hi!
I feel like this should be obvious but for folding, can you run multiple graphics cards without them being in crossfire or sli?  I see great local deals on used cards and I would like to boost my PPD.  I upgraded my graphics card to be able to accomodate another card but I didn't want to have to search for my exact card.  Can I just grab any card and run it independently?
"The doctors X-rayed my head and found nothing."  - Dizzy Dean
i7-4770K, ASUS Z87 Gryphon, EVGA GTX 780 Ti, 16 GB Kingston Fury RAM, Crucial M500 240 GB, 1TB Seagate Barracuda, Cooler Master Hyper 212 Evo, Seasonic 760W PSU, Asus BD, Phanteks Evlolv mATX (Gunmetal).
https://linustechtips.com/topic/107004-fh-multi-gpu-question/
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/107004-fh-multi-gpu-question/#findComment-1430341
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
https://linustechtips.com/topic/107004-fh-multi-gpu-question/#findComment-1430355
Thanks!
https://linustechtips.com/topic/107004-fh-multi-gpu-question/#findComment-1430387
