Hey LTT forum,
So with Zen 2 around the corner and my 'itch' acting up again I decided to upgrade my system.
From my current build I plan to keep the GPU, Storage HDD, NVME SSD and probably the CPU cooler, so this is almost a fully new build.
This system will solely be used for gaming, I play CSGO a lot so I hope AMD is at least equal to Intel in this game by now, and other than that I play loads of different games.
Also I'll overclock the cpu as high as I can.
CPU: 3700X (or 3800X if it OC's higher) or if I can't contain myself the 3900X
Mobo: no clue so far, maybe ASUS if their MemOpti whatever technology isn't a gimmick, I want something solid that doesn't completely breaks the bank (Crosshair VIII Hero if its affordable)
RAM: 2x8GB of something fast
GPU: Asus Dual GTX 1070 (fixed as this comes from my current build)
PSU: Corsair HX750 V2 (I want an PSU that lasts me a decade and gives me the most stable power for overclocking, efficiency is less important so doesn't have to be platinum rating)
CPU Cooler: Currently Corsair H115i, might switch to D14 of D15 if I think I could get a higher OC, I really want to go custom wc again but I don't want to pay for it again ?
Case: NZXT H510i looks really cool but I'm worried about its cooling performance
So yeah, shoot! I know we still don't know a lot about the motherboards or what memory will perform best but whatever.
GAMING PC CPU: AMD 3800X Motherboard: Asus STRIX X570-E GPU: GIGABYTE RTX 3080 GAMING OC RAM: 16GB G.Skill 3600MHz/CL14  PSU: Corsair RM850x Case: NZXT MESHIFY 2 XL DARK TG Cooling: EK Velocity + D5 pump + 360mm rad + 280mm rad Monitor: AOC 27" QHD 144Hz Keyboard: Corsair K70 Mouse: Razer DeathAdder Elite Audio: Bose QC35 II
WHAT MY GF INHERITED CPU: Intel i7-6700K (4.7GHz @ 1.39v) Motherboard: Asus Z170 Pro GPU: Asus GTX 1070 8GB RAM: 32GB Kingston HyperX Fury Hard Drive: WD Black NVMe SSD 512GB Power Supply: XFX PRO 550W  Cooling: Corsair H115i Case: NZXT H700 White
https://linustechtips.com/topic/1069795-help-me-plan-my-zen-2-build/
Bump: Could use advice on cases mostly
If you're going for an air cooler, the Fractal Design Meshify C has plenty of airflow to feed the cooler
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
