First PC Build Ever
12 minutes ago, CullenM_2004 said:Recently I started to develop an interest in PC Gaming and I want to build my own 'budget' gaming PC so I can play games such as Fortnite, CSGO, Battlefield...etc. Currently I play on an IMac and it has awful gaming performance. So, as my first PC build I want to be able to play at a much higher FPS. Anyways here are the parts I have decided, i just need assistance on picking out the rest
Parts I Have Picked So Far:
CPU - Ryzen 5 2600 With Wraith Stealth Cooler
GPU - RX 580 8gb
RAM(memory) - 16GB (i need help choosing specific ram sticks)
Those are the few parts I have picked so far. I need help choosing the right (2x8gb) RAM STICKS, Motherboard, Hard Drive, SSD, Power Supply, case, fans, and internal wifi card
My goal is to be able to play Fortnite on low settings and 100% 3D resolution at 144 FPS so i can play on a 144hz monitor.
Also, I need a internal wifi card to install on my MotherBoard because i will not have ethernet availability for a while. My budget is around $650-$750, it could go a few dollars above. For a case i dont need anything too special, I want something that has a easy to remove side panel (it could be tempered glass) for a decent price >$70. Anyways, thats what i want in my PC build and I would extremely appreciate any/all help from other. Thanks for reading and I hope someone will help me out.
Here is a pcpartpicker list
You could remove the 1tb hdd if that is a problem for you and you can downgrade the ssd capacity but in my opinion this is a really good system. If you have any questions just ask.
