MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1067344-will-this-build-work/#findComment-12599665
@GoltGooner
share this link
https://linustechtips.com/topic/1067344-will-this-build-work/#findComment-12599675
3 hours ago, GoltGooner said:
What is the pc going to be used for ? I wouldn't buy a dual core i3 when you can get a much cheaper Ryzen cpu. The gpu is also bad.
https://linustechtips.com/topic/1067344-will-this-build-work/#findComment-12600147
