Need help with new PC build
Solved by renz62,
I think you wouldn't really need an i7 for that kind of use., an i5-4670k and a motherboard of your choice would suffice your work needs ![]()
i7 is mostly recommended for video editors and rendering applications. You can just use the saved money to buy a better graphics card, like a GTX 780 which will make you play most games at max settings ![]()
Because at the end of the day, the graphics card will be the one doing all the work in games
