So I just downloaded THX and saw something called "Crossover Frequency" and it goes from 10Hz to 1000Hz,
My headphones says they have a frequency from 15-28000Hz but i don't know nothing about sound..
I just wondering what is the best frequency for my headphones, or what frequenzy i will get the best sound quality from.
I sure have to learn more about this myself, but if anyone of you can give me a start with it, it had been awesome :)
https://linustechtips.com/topic/106713-audio-help-needed-hz/
@Exonoz
Typically, Crossover is a reference used for blending separate frequencies between different component speakers.
For example, running a set of woofer speakers that play the higher frequencies and a subwoofer. You would set the crossover for the subwoofer to play the frequency ranges of e.g. 20hz to 200hz. Then set the desktop speakers to play the frequencies from 201hz up.
At least, that's what I know crossover to be, for audio speakers. For headphones, I can't figure a use for using crossover.
I would just ignore it/turn it off ^_^
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/106713-audio-help-needed-hz/#findComment-1426311
Guest
