Try running DDU to clear out your video drivers then download and install the newest.https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
If that doesnt help, then I think your GPU may be dying.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1066818-help/#findComment-12594748
@deadless
what GPU do you have ? Did you overclock it at all?
Are your drivers up to date ?
looks slightly like artifacting
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1066818-help/#findComment-12594751
Just now, deadless said:
ive a asus gtx 650ti boost heres the link https://www.asus.com/Graphics-Cards/GTX650TIBDC2OC2GD5/
As @Skiiwee29 has mentioned, download DDU get rid of all drivers and reinstall the latest driver for your GPU.
if that doesn’t help it could be that your graphics card is dying, it’s almost 7 years old now
https://linustechtips.com/topic/1066818-help/#findComment-12594760
ill try that hopefully its not my gpu.
https://linustechtips.com/topic/1066818-help/#findComment-12594763
Let us know how it goes
https://linustechtips.com/topic/1066818-help/#findComment-12594767
1 minute ago, Alexsolo said:
To me that looks like GPU artifacts.
http://www.playtool.com/pages/artifacts/artifacts.html
Try to update drivers, even use a different monitor cable or even monitor. Else you may be in possession of a dying graphics card.
A new GTX 1650 would be a substantial upgrade and is budget friendly. Perhaps even a used 1050TI or 1060 would do you well.
if it is dying just gonna go with it as long as i can my whole system could be upgraded.
https://linustechtips.com/topic/1066818-help/#findComment-12594826
