FYI, using PCPartpicker is much easier to get a part list.
Also, assuming you're in the US,
PCPartPicker Part List
Type Item Price
CPU AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor $147.90 @ OutletPC
Motherboard ASRock - B450M Pro4-F Micro ATX AM4 Motherboard $68.99 @ SuperBiiz
Memory G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory $73.98 @ Newegg
Storage Kingston - A400 240 GB 2.5" Solid State Drive $26.99 @ Amazon
Storage Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive $45.56 @ Amazon
Video Card EVGA - GeForce RTX 2060 6 GB XC BLACK GAMING Video Card $329.99 @ Newegg
Case Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case $49.99 @ B&H
Power Supply Corsair - CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply $52.88 @ OutletPC
Wireless Network Adapter Gigabyte - GC-WB867D-I PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter $33.89 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $870.17
  Mail-in rebates -$40.00
  Total $830.17
  Generated by PCPartPicker 2019-05-25 01:34 EDT-0400
EDIT: I just read that you already got the Q300L and the Kingston SSD. The SSD is completely fine but the case has bad airflow, it should be fine temperature-wise, though if I were you I'd return the case and get a different one.
https://linustechtips.com/topic/1066750-my-first-pc-build/#findComment-12594207
What's the budget after the items you bought?
At a lower budget you could do something like:
I wouldn't waste money on a 2400G if you don't need the APU. The 1600 is more powerful and cheaper.
https://linustechtips.com/topic/1066750-my-first-pc-build/#findComment-12594493
