3 minutes ago, YoFavRussian said:
My first question is why? These may work together because memory compatibility is less finicky now that it used to be.
If you're looking to do a setup with these colors the Ballistix is available in both white and gray.
https://linustechtips.com/topic/1065881-ram-help/#findComment-12585541
Just now, CaptainCrawfsh said:
well, i realized 8gb isn't cutting it (I have the ballistix already). I need 16gb, and the vipers are cheaper, so I was just wondering. I don't care about the colors.
I understand, just to prevent any hassle with compatibility issues, I would purchase the same RAM. But double check to make sure the model number on your sticks matches the one that you've linked on Amazon.
https://linustechtips.com/topic/1065881-ram-help/#findComment-12585546
