I'm trying to squeeze the most performance I possibly can out of my chip, an i5-9400f, not being overclockable, by traditional means that is, I've turned up the power limit, and messed with some turbo boost settings through Intel XTU, but I saw the Reference Clock slider, and began wondering. Is this the same as base clock? What hardware will it affect? Is it safe? Should I stick to specific increments? If anyone has information on this issue, or other tips about overclocking a non-k CPU through Intel XTU, I'd be thankful to hear them.
https://linustechtips.com/topic/1065356-reference-clock-over-clocking/
by XTU naming, yes.
last time I tried. it didnt worl. Is this a Z board?
Desktop benching:
21 hours ago, Jurrunio said:
Last time I tried. it didnt worl. Is this a Z board?
My board is an MSI MPG Z390. I went ahead and tinkered with the Reference Clock, and was able to get it up to 102.7 MHz stable. It does seem to have increased my ram speed, but I've achieved an extra 50 marks or so on XTU's benchmark. After trying to over volt to see if I could achieve a higher clock, XTU reported current throttling. What would be a safe current limit in my case? I have a Thermaltake 750W power supply of that means anything. Also, is an extra 1 volt too much? (Offset, I can't change the base voltage.) Everything seems stable, other than the current limit, I'm still achieving sub 80°c.
Edited by Imitheos
Just max that out, your CPU wont pull more than needed current anyway
Of course. Max for overclocking is like 1.4V, most boards give you 1.2V or higher when stock already.
Desktop benching:
What voltage does the i5-9400f run at stock? With an offset of .7V I wasn't able to achieve even a .1Mhz bumb, so I don't think I'd be able to with anything less. I might as well just leave it at stock then right? Or is there something else I should try? My BIOS doesn't have a Maximum or Minimum for CPU Current, what should I put in? Thanks.
