1 hour ago, Mero_de said:
Hello everyone,
so i have got my new RTX 2070 now and planning to buy a new monitor.
Current Monitor is 1080p 60 Hz
found this one : CJG50 1440p 144 Hz NO Gsync and No HDR and no Freesync.. wtf? 300$. should i get it ? how important is freesync gsync and hdr ?
HDR10 is awesome, i got my new 4K today
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1064947-1440p-144fps/#findComment-12576973
If you can stay above 144 FPS FreeSync is redundant.
I would be more concerned of ghosting on that VA panel.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1064947-1440p-144fps/#findComment-12576975
21 minutes ago, Mero_de said:
Hello everyone,
I wouldn't touch that thing if its 144hz but no freesync or g-sync.  This is a recipe for disaster,  Once your frame rate drops below 144fps its gonna get laggy or not smooth.  When freesync can give you a smooth experience either at 144fps or 80fps ,, you won't really notice a difference.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1064947-1440p-144fps/#findComment-12577005
I sometimes play games capped at 90 fps with FreeSync disabled (used to have an AMD GPU too), and it was fine on my monitor. I think you overestimate the benefits of FreeSync.
33 minutes ago, Mero_de said:
what is ghosting ? and what do you mean by redundant.
Ghosting means that when the picture changes quickly (e.g. when you turn the camera fast), the picture will not transition immediately and you will see "ghosts" of the previous camera angle briefly.
That monitor you are considering seems to have ghosting issues.
Unraid Server
https://linustechtips.com/topic/1064947-1440p-144fps/#findComment-12577044
im confused a bit.. once i search for 1440p, 144 Hz curved the price jumps to 450+..
what would be the difference between 1080p 60 Hz and 1080p 144 Hz ? Better image? faster gaming? im  already getting +150 in most games i play on 60 Hz
im i going to get lower fps when i get 1080p 144 Hz ?
the reason why i need a new monitor is that although i have RTX 2070 the image still sucks,, even when i set setting to ultra the image just SUCK
@Nocte
https://linustechtips.com/topic/1064947-1440p-144fps/#findComment-12577281
28 minutes ago, Mero_de said:
how about 4k? why the heck im finding 4k Monitors cheaper that 1440p 144?! should i get a 4k ? how would the experince be ? linus said gaming on 4k is dump but i dont really get it
Those aren't worth buying. ;)
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1064947-1440p-144fps/#findComment-12577335
3 hours ago, Mero_de said:
Hello everyone,
Your best bet is to save up and get a good quality monitor.
There are truly some excellent 1440P 144Hz gaming monitors available.
If you shop price you will regret it.
https://linustechtips.com/topic/1064947-1440p-144fps/#findComment-12577346
