Exposed sata cable
1 minute ago, LuckyAsFox said:That's not bad. Will 450W be enough though?
Yeah, your system probably only uses around 250w looking at your specs.
Forgot to mention, make sure you get the one with the grey label which is the new one, and not the one with the orange label which is the older version.
https://www.mwave.com.au/product/corsair-vs-series-v2-450w-80-plus-white-power-supply-ac12710
If you're planning on upgrading the system sometime soon you might want to grab the CX450 (2017, grey label) for $69. The CX450 is a better PSU than the VS450, but for your current system the VS450 would be fine.
https://www.mwave.com.au/product/corsair-cx450-450w-80-plus-bronze-power-supply-ac09241
Same prices at Scorptec/Mwave/PCCG (PCCG is in Melbourne so you'd need to pay for shipping)
Scorptec has a shop in Auburn and Mwave has a pick up location in Lidcombe.
