Hiya Errybody!
I decided after the video a few weeks back for Gaming on Linux that I would try my hands again at Linux.
I got everything installed and dual-boot is running beautifully, but the only way for me to get online is via Bluetooth tethering form my phone.
I know my PC can connect because when I was running the live-usb, I was on YouTube no probs.
After the install, no networks are showing. I have a TP-LINK Archer T9E PCIE network card with no official Linux drivers available from them. Not that I'd know right now how to install them on Linux XD
Soo if anybody has some ideas I may try, please help a brother out!
https://linustechtips.com/topic/1064478-manjaro-wifi-issues/
I did some research about this. Things aren't looking great.
Tl;dr - your device may have been misconfigured/installed. It looks like the bluetooth may interfere with wifi working. You might be able to follow these steps to fix it: https://forum.manjaro.org/t/broadcom-wifi-fails-to-install/46316/6
You might be able to use an alternate driver by running this command: sudo pacman -S broadcom-wl-dkms
But even if it installs, you might have problems: https://forum.manjaro.org/t/broadcom-bcm4360-works-but-very-very-slow-and-connection-is-unstable/80443
This is because this device isn't supported by the official kernel - https://wireless.wiki.kernel.org/en/users/Drivers/b43?highlight=(b43)#Supported_devices . According to my research, your device uses bcm4360 chipset.
Good luck!
https://linustechtips.com/topic/1064478-manjaro-wifi-issues/#findComment-12573904
10 hours ago, Enessi said:
Hiya Errybody!
Doesn't look to me it's officially supported, what does the manjaro driver manager show? Connect to the ethernet when installing the driver
https://linustechtips.com/topic/1064478-manjaro-wifi-issues/#findComment-12573933
