Hi I am currently testing speed on my network ahead of an upgrade and are currently running into an issue with Iperf3 and server 2012.
I can run Iperf as a client from my server 2012 file server, but when i try to run it as a server and connect to it i get the error "iperf3: error - unable to connect to server: Connection timed out".
I have opened the port for inbound on the server with no success.
any thoughts?
https://linustechtips.com/topic/1063996-iperf-issue/
Maybe your firewall is blocking the connection?
Current PC
CPUIntel Core i9 9900k
GPUGTX 1080 8GB FTW EVGA
MotherboardASUS PRIME Z370-A II
RAM: Corsair Vengeance LPX (2x8GB) DDR4 2400 Mhz
Storage 1: Samsung 850 EVO 250GB
Storage 2: Hyper X 240GB
PSU: Corsair RM750 80 Plus Gold 750W
Peripherals: Logitech G502 Hero//Corsair K70 MK 2 Cherry MX Red
Display: BenQ XL2430T 24-inch 144Hz
https://linustechtips.com/topic/1063996-iperf-issue/#findComment-12568409
1 hour ago, mtz_federico said:
Did you add the rule for tcp, udp or both?
iPerf can use both and I think it uses tcp by default, I just open both udp and tcp for iperf.
I added it as an incoming rule for port 5001 (both TCPand UDP) as stated when i start the iperf2 server but connection still cannot be made
https://linustechtips.com/topic/1063996-iperf-issue/#findComment-12568856
Can you pingteh server from the PC you are trying to iPerf from?
Current PC
https://linustechtips.com/topic/1063996-iperf-issue/#findComment-12568862
1 minute ago, mtz_federico said:
Are both clients iperf2? One of them could be iperf3
Yeah to be fair. You do mention using iPerf3 in your first post, but later on you change it to iPerf2?
Current PC
https://linustechtips.com/topic/1063996-iperf-issue/#findComment-12568929
yes i can no problem
yes both server and client are using iperf2, i switched to iperf2 to see if there were any issues specific to iperf3
https://linustechtips.com/topic/1063996-iperf-issue/#findComment-12580635
