First build
Go to solution Solved by SliceT,
You can check this topic...plenty of opinions.
Shopping for my first build, and I've pretty much lined everything out, except I'm having trouble deciding between Asrock taichi x470 and the rog strix x470-f .
I like the look and the fact the taichi has wifi (its needed honestly ) but I've heard the bios is crazy bad. I just want to build a nice machine with out losing performance.  Which I feel Is a possibility if I dont go with the strix .
Here's a shopping list I've compiled on Amazon with both MOBOs of course
https://www.amazon.com/hz/wishlist/ls/1GPMT59VN83K4
Any advice would be appreciated!
Thanks
https://linustechtips.com/topic/1063930-first-build/
The BIOS, from what I hear, is just fine.. I would get the Taichi, it's the BETTER board and has wifi..
For $60 less you can get almost the same thing from Newegg, except the combo only includes the R5 2600 (very similar anyway when overclocked)..
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1063930-first-build/#findComment-12567694
  • 2 weeks later...
