Heyy guys ,
i am from the Uk and i have £100 which is $152.84, Now i'm trying to find a AMD motherboard that holds 8 GB RAM , at least 1 PCI express slot for my radeon HD 6670 graphics card and also USB 3.0 , but also out of the £100 / $152.84 im trying to get a 4 core processor ( AMD ) does anyone have any ideas on what i can get motherboards and processor For £100 /$152.84 ?
Thanks Drew
https://linustechtips.com/topic/10639-amd-motherboard-help/
£100 really isn't enough for a motherboard and a processor unfortunately. Would recommend you save up a little more, £200 should be enough to get you a half decent motherboard with the features you want, aswell as a 4300 Piledriver AMD processor.
https://linustechtips.com/topic/10639-amd-motherboard-help/#findComment-113928
thanks dave . i'm really stuck on what to do, I have £100/ $152.84 , I currently have a Intel pentium dual core E5400 socket 775 LGA CODE NAME : WOLFDALE processor , on a Foxconn G31S motherboard , now i used the £100 to get 8GB RAM , what Intel motherboard would i be able to use my current processor in and then be able to upgrade to a intel i5 ? or any other suggestions ?
https://linustechtips.com/topic/10639-amd-motherboard-help/#findComment-113950
thanks dave . i'm really stuck on what to do' date=' I have £100/ $152.84 , I currently have a Intel pentium dual core E5400 socket 775 LGA CODE NAME : WOLFDALE processor , on a Foxconn G31S motherboard , now i used the £100 to get 8GB RAM , what Intel motherboard would i be able to use my current processor in and then be able to upgrade to a intel i5 ? or any other suggestions ?[/quote']
*Edited* - saw your other thread you created. :D
https://linustechtips.com/topic/10639-amd-motherboard-help/#findComment-113973
