Urgent Help
Go to solution Solved by Skiiwee29,
Z270 will not work with an i7 3770.. the 3770 will only work in older 6x or 7x series boards.. not a 270.. thats your problem.
Hi, I recently upgraded my pc, I installed a new motherboard, and new ram.
Problem: when turning on the pc, everything lights up fans are going ect.... but, no USB, or HDMI ports are working. GPU fans turn on a off every 2 seconds. Stressing out.
Components:
- i7 3770
- strix Z270H Gaming/K1
- Corsair 16gb 3000
- 980ti EVGA
- 600B EVGA PSU
- 240 & 480 SSD
- 1TB HHD
- Cooler Master 212 Evo
if you guys can help that would be great!
Thansk, Dec.
Cpu Intel Core i7 (3770) 3.4GHz Qaud Core - MB MSI Intel B75MA-P45 - RAM Hypertec Hyperam 32GB - GPU EVGA Nvidia GTX 980 ti 8GB SSC - Case Cooler Master K-Series K380 Storage SSD 240GB Sandisk WD 1TB Caviar Blue - PSU EVGA 600W Bronze - Display BENQ 22' GL2450 - Cooling Cooler Master Hyper TX3 Evo
https://linustechtips.com/topic/1063475-urgent-help/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1063475-urgent-help/#findComment-12562685
What i7 will work with this board?
https://linustechtips.com/topic/1063475-urgent-help/#findComment-12562690
Only i7s that will work in that board are the 6700 or 7700.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1063475-urgent-help/#findComment-12562695
What would you say is the best bang for buck?
https://linustechtips.com/topic/1063475-urgent-help/#findComment-12562709
the 7700 is newer and slightly faster, but you wont notice any real difference between the 2. Get whichever you can get for cheaper.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1063475-urgent-help/#findComment-12562718
