Hi guys,
I already searched for quite some time but couldn't find a satisfying answer so here is my Problem/Question.
I recently bought a pair of Akg k240 MK2 together with the zalman zm mic 1.
Before that I used the Logitech g35 for 5 years.
Now that I used the Akgs for some time I adapted to stereo sound and like it a lot just the zalman sounds quite tinny ( I know it's very cheap)
I read a lot about dac amps and Audio-Interfaces being mandatory and I just used my onboard chip (alc1220). I like the sound from the Akgs but they aren't very loud on max volume but other than that I don't really know if the sound could be better mainly because the only headphones I ever used where the g35s...
So here is my question: Could I improve the sound from my Akgs and the one from my mic with a budget dac amp or Audio-Interface ( around 80 dollars) or is it not really worth it to get a dac amp or interface for the same amount of money as my headphones?
In the future I might upgrade to a real microphone but not at the moment.
The ones I looked at are:
Behringer Um2
Behringer Xenyx302
Fiio E10 + 1 Dollar USB soundcard for the zalman
Behringer Umc202
Could not really find a dac amp with mic input in the price range that's why I looked at Audio-Interfaces
Or can you recommend something else?
Ps. Buying from Germany but I guess that's not that important
https://linustechtips.com/topic/1063002-dac-amp-or-audio-interface/
17 minutes ago, Purpleee said:
Hi guys,
Behringer Um2
Behringer Xenyx302
Behringer Umc202
Your not going to get much with only 80 US dollar.  However yes the sound card does not have a HP amp.  Its just a input.  If you get a HP amp or DAC interface then yes your volume and possibly the quality will improve to the point its very noticeable and what not.  Just see which one you like better with the list you provided.  Look at their specs with like DB level and SnR and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Thank you!
The only cheap DAC amp I can think of with a mic input is the syba sonic.
46 minutes ago, Purpleee said:
I read about that one but some people said that the mic quality is really bad is that true?
Never heard it. So I don't know I just know of jt. Honestly your zalman probably won't at all benefit from getting a sound card. All I can say when I updated my setup from onboard to a fiio e10k with my k240 they definitely benefited. I found the low end got tighter and stronger and the imaging and sound stage improved.  I believe that's attributed to the fact that the headphones are now properly powered.
So you think it's worth it paying the same amount of money for a dac amp that you pay for headphones?
1 hour ago, Purpleee said:
I did some additional research and found the FX Audio DAC-X6. A lot of people say its better than the Fiio E10k. But the k240 mk2 dont have a lot of bass but only the Fiio E10K has a bass boost. So which should i go for between these two?
Look into using a equalizer Apo with peace gui.
