Dark rock pro 4
Go to solution Solved by Constantin,
Yes, it will..
Yes, it will..
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1062906-dark-rock-pro-4/#findComment-12557932
I google the dimensions on the official site, you can check them yourself
https://linustechtips.com/topic/1062906-dark-rock-pro-4/#findComment-12558092
Just did put a DRP4 on a x470i itx board in a H500i and some G. Skil RipjawV rams, everything fitted. Didnt even need to remove the 25mm case fans or the front cpu fan. Just to make sure you can go to be quiets webpage and look if ur motherboard is compatible  https://www.bequiet.com/en/motherboardcheck
https://linustechtips.com/topic/1062906-dark-rock-pro-4/#findComment-12570703
I'm sitting here looking at my Dark Pro 4 inside my H500i, yes it fits, perfectly.
 No Issue OP.
I7 9700k- MSI Z390 Gaming Edge AC - Be Quiet Dark Pro 4 - Corsair Vengeance LPX 3200 2X8GB - EVGA RTX 2080 TI Black Edition - WD BLACK NVMe M.2 500GB -  EVGA Supernova 650 P2, 80+ Platinum -Nzxt H500 - Display Dell S2721DGF 27" - Keyboard- Razer Huntsman Mini 60%  - Mouse- Logitech G203  - Headset  Astro A50 2019 Edition - Speakers - Logitech Z623
https://linustechtips.com/topic/1062906-dark-rock-pro-4/#findComment-12574649
