Hi all,
I'm looking into a build for a friend. Budget is around 1000 euro in the Netherlands and I came up with this:
Or I was thinking this:
What do you guys think? Any other recommendations? He's very keen on the case so that cannot change. His GPU is a MSI 1070, no storage needed.
Cheers.
"To the wise, life is a problem; to the fool, a solution" (Marcus Aurelius)
https://linustechtips.com/topic/1060998-build-for-friend/
New CPUs in a couple months, worth the wait if your friend is patient.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1060998-build-for-friend/#findComment-12539367
Just now, Zandvliet said:
Yess, I told him. He's not ;)
In that case just go with Ryzen so he has an upgrade path, and maybe cut the PSU down to 650 watts, a more reasonable wattage, if saving money matters. Also, is storage covered? It's not on the lists, nor GPU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1060998-build-for-friend/#findComment-12539375
Yeah, that was my thoughts too. Alright I'll look into the PSU. Yes, GPU and storage is covered.
https://linustechtips.com/topic/1060998-build-for-friend/#findComment-12539381
What GPU is in there already? Would be good to know if its a current GPU or an older one to which higher end CPU might be a bit of overkill.
Also is this case mandatory? Its far overpriced and stupidly heavy (looking at about 20kg on the case alone)
CPU
Intel® Core i9 9900K 8 Core 16 Threads
Motherboard
ASUS® ROG Strix Z390-E
Memory (RAM)
32GB Corsair Vengeance Pro RGB
Graphics Card
MSI RTX 2080 Gaming X Trio
1st Drive
500GB Samsung 970 EVO NVME
2nd Drive
1TB Samsung 970 EVO NVME
3rd Hard Disk
480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW)
4th Hard Disk
2TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM
5th Hard Disk
Power Supply
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling
Corsair H150i Pr 360mm AIO
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1060998-build-for-friend/#findComment-12539397
Check the OP. Yes, the case is mandatory and the GPU is 1070.
https://linustechtips.com/topic/1060998-build-for-friend/#findComment-12540292
I would go with a cheaper cooler/psu and put the savings towards a better board such as the ASRock X470 Taichi especially if you want to upgrade to an 8+ core in the future.
PCPartPicker Part List
CPU Cooler: Cooler Master - MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  (€125.00 @ Paradigit)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  (€109.00 @ Paradigit)
Total: €234.00
Generated by PCPartPicker 2019-05-05 18:29 CEST+0200
https://linustechtips.com/topic/1060998-build-for-friend/#findComment-12541243
