I am building my own PC and I'm stuck on a problem with the windows I need drivers that go with windows 10 32 bit / a AMD 4300 CPU/m5a78L-m plus Asus motherboard/  and a nvidia geforce gt 1030 graphics card I really would appreciate the help I have been stuck for a month now I dont know what to download
I havnt built a computer before and I have the disk from gigabyte for the drivers but i dont know how this works i tried looking it up and nothing
https://linustechtips.com/topic/1060719-i-need-help/
Running x32is not the best in the first place.
It's 2019, most of the stuff are running and need x64.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1060719-i-need-help/#findComment-12537369
I got a 64 bit USB for the 64 bit but when I checked it out it ended up being 53 GB and not the full 64 as advertised so I'm stuck at 32 for now and these are parts I'm able to afford
https://linustechtips.com/topic/1060719-i-need-help/#findComment-12537377
Uhm what? 64bit and 32bit refer to OS architechture. Your CPU supports x64. 54gb sound like USB drive or maybe SSD. That size SSD is too small to be used as OS drive for Win10. You need atleast 120gb to do it without issues. Fully updated Win10 is ~45-55Gb.
Whats your actual issue? Installing OS? If so, does your motherboard have option to boot from USB? It should, but it might be oddly named.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1060719-i-need-help/#findComment-12538892
