is it staying on post code b4 after going through those other ones?
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/1057941-asus-xi-hero-problems/#findComment-12511309
where you using all this hardware on a different motherboard beforehand and did it work then?
https://linustechtips.com/topic/1057941-asus-xi-hero-problems/#findComment-12511324
dumb question but your display cable is plugged into the gpu correct
https://linustechtips.com/topic/1057941-asus-xi-hero-problems/#findComment-12511350
have you tried phyiscally removing the gpu then plugging into the igpu?
https://linustechtips.com/topic/1057941-asus-xi-hero-problems/#findComment-12511363
Clear cmos
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/1057941-asus-xi-hero-problems/#findComment-12511912
