Hello everyone, I've been thinking about upgrading my computer pretty soon. This is roughly my current system, though the case is different. I've been using it for about a year and while I'm happy with it for my engineering classes and light video gaming, I want to upgrade it!
I'm between 2 different upgrade options: CPU or GPU.
For the CPU, I would get a Ryzen 5 1600.
For the GPU, I would get an RX 560 (used or otherwise).
I wouldn't mind getting something different for either of those, but I don't need anything better than 1080p for gaming (I have a 16x10 I game on, so I guess it's technically 1920x1200) and I edit video footage for occasional YouTube videos.
Thoughts? Opinions? Questions about why I have such weird storage devices? Should I just get both? (If it changes things, I'm graduating in May and hopefully will have a job right away.)
https://linustechtips.com/topic/1057038-upgrading-my-first-build/
Really the 1600 is a nice upgrade, (More cores, multi threaded) but unless you are doing CPU heavy stuff, the 1200 will support a newer GPU for 1080p gaming just fine.
The 560 is only a little upgrade from the 550. A used RX 580 is ~$90-100 USD on Ebay. This will be a great cost to performance upgrade. That's where I would be aiming.
8 hours ago, Ty34er said:
Yeah, I figured I should have gotten the 560 when I first built it. Thanks for the advice!
Well... To clarify, I don't think either is the right buy.
A 580 is where you wanna be, with a 570 on backup if you can't front the used market pricing.
For gaming the GPU first would be of more benefit. A 1200 isn't much of a bottleneck to the RX 580. It will bottleneck a little, but the better performance gain in gaming will come from the GPU upgrade.
Likewise if it's more so the editing you do, CPU first.
The only editing I do is splicing clips together and maybe adding a simple text overlay. Nothing fancy.
Alright, well, I guess I'll focus on finding a nice RX580, unless anyone has any suggestions about Nvidia cards.
Keep a lookout for a Vega 56 as well, those can go toe-to-toe with GTX1660Tis and who knows if you might find a great deal for them.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
That depends on your budget. The used market is an interesting thing. The GTX 1060 6GB would be the comparable NVidia card to the RX 580, and they cost a chunk more and are a tad older. For only a little more, you might be able to find a nice GTX 980/ti or an R9 290X, which would be a step up, but again an older card for support / warranty purposes.
The RX550 and 560 are almost the same, not worth it...
The lowest GPU Upgrade that makes sense is an RX570, if possible 8GiB VRAM.
CPU, as said, a 2600 would be nice, though you have a pretty low end Board...
"Hell is full of good meanings, but Heaven is full of good works"
Yeah, I pretty much only got this board because it had a deal with the 3 1200 and had enough for what I needed at the time.
Thanks everyone for the advice.
