Monitor
Hazinc
i build a pc with i5 9600k and rtx2070, what monitor should i go with? is the asus vg258qr fine? what monitor should i go with?
I would suggest this monitor. https://pcpartpicker.com/product/8MrmP6/lg-27gk750f-b-270-1920x1080-240hz-monitor-27gk750f-b Its the monitor I use and its awesome! I know it says 2ms but if you disable freesync which you will since you have a nvidia card you will get 1ms. I have been using it for around half a month now and its awesome!
