Bluray drive inside case without DVD slot opening.
Solved by dfsdfgfkjsefoiqzemnd,
A Bluray reader will be 5.25", a HDD cage is 3.5". So the reader simply will not fit ... at least not without some serious case modifications.
If you rarely ever use one, I'd suggest getting an external reader.
Featured Topics
Agall ·
xKempo ·
Posted in Troubleshooting0 -
4
Dcorrigan97 ·
Davidf4e ·
Posted in Troubleshooting1 -
3
2
3
Bobzcpu ·
Posted in Power Supplies2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
