Commander Pro Issues?
Go to solution Solved by Skiiwee29,
Seems HWinfo64 was the cause and problem of it. Uninstalled it and rebooted, and now everything is working properly.
So I ordered a Corsair Commander Pro and it arrived today. I have 6 ML120 Pro fans, 3 120mm 3 140mm hooked up to it for now with the intentions of changing out to LL series fans in the near future. Problem im having is that iCUE isnt recognizing the fans properly. It seems to (usually, they sometimes drop out) read Fan 1 & 2, albeit with very wild RPM ratings, but 3-6 doesnt seem to register at all. Full system specs are in my signature. All 6 fans are powered up and running no issues, but I can not control them this way to set my fan profiles I want.
I have uninstalled Asus Aura Sync as I know it can cause compatibility issues since they use the same bus to talk from what ive read. I have also uninstalled my other software I was using to control my fans and monitor, Argus Monitor. Only thing I haven't uninstalled is HWinfo64 or MSI Afterburner.
Any ideas/thoughts/tips/tricks you guys know of?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1055638-commander-pro-issues/
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1055638-commander-pro-issues/#findComment-12490395
