Hello guys i have got a problem with my pc, the problem is that when ever i try to play any game and i mean any the cpu and the gpu rarely go to 80% usage most of the time they sit around 40% CPU and about 40%GPU, and the most weird of all is when i play a game with high/ultra the fps stays the same but the cpu usage goes up from 40% to 60/80% usage. How can i make my pc go 90+% on every game i play?
My ecs are :
2x Intel xeon x5355
NVIDIA Geforce GTX 770
8x 1gb 800ghz ram DDR2
power suply 750W
And yes this is a server from 2003
https://linustechtips.com/topic/1053460-cpu-and-gpu-low-usage-in-games/
You are sporting a rather slow 8 cores (and some fairly low memory bandwidth), are you examining your per core usage in games or just the overall CPU usage? If it's at 40% CPU usage max, you might have 3 cores maxed out and the rest can't be leveraged.
Primary PC:
PSU tier list
How many watts do I need?
A dual socket system may impact the performance of applications that are not aware of it because there's a non-trivial amount of overhead to share data between the processors. Try setting the process affinity to one half or the other (assuming this is how Windows reports it) and seeing if performance improvements.
3 hours ago, Orkapoess said:
800GHZ!?!?!?
It from the future lol
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
7 hours ago, Orkapoess said:
800GHZ!?!?!?
Ryzen CPUs have joined the chat
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
My cpu use all my cores even though sometimes only a phew cores go 60 and the rest stay at 40. I can play nier automate on high setting so i dont see why i cant play GTA 5. What i have tried is see how far i can push it to have it play at 90+cpu usage, and it seems to me that when i go under 30 fps on any game that the cpu will go up and if the game is at 40 fps for example it will stay as low as before.
