the arctic accelero twin turbo is great, and it's really quiet as well as cheap.
I'd link you one,but I have no idea where you'd be buying from.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/10532-cooler-for-6870/#findComment-114647
The best aftermarket GPU coolers for the 6870 are the:
Arctic Cooling XTREME Plus II - 45.99
GELID Rev. 2 ICY VISION - 42.99
Both GPU coolers are great. Personally I prefer theArctic Cooling XTREME Plus II because it has three 92mm fans that keep the GPU silent and cold. The GELID Rev. 2 ICY VISION is a cheaper option and has uv reactive fans that also spin quiet. In conclusion, both GPU coolers are fantastic choices that will definitely beat the stock cooler. Any one is a great choice. It really depends on what your looking for like color, size, fan amount, and sound.
https://linustechtips.com/topic/10532-cooler-for-6870/#findComment-114802
The accelero extreme 3 is a possibility but it cost 80$ but you ll be able to use it on your next card,
You could also go for the Dwood mod which is sticking an h60 or another AIO on the gpu using some brackets made by a guy over at overclock.net.
The bracket cost about 5$ and you need the AIO
http://triptcc.com/shop/
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/10532-cooler-for-6870/#findComment-114810
out of curiosity where did you find it for $46?
https://linustechtips.com/topic/10532-cooler-for-6870/#findComment-115735
I can only find these at about 90$ I would buy 2 right now at that price...(if they ship to canada)
https://linustechtips.com/topic/10532-cooler-for-6870/#findComment-115769
Wow these guys fears Bots like now tomorow... I had to enter like 10 verfification codes before seeing the item...
https://linustechtips.com/topic/10532-cooler-for-6870/#findComment-115779
