Hello,
I have a bluetooth dongle connected to USB 2 port on PC. It is no name bt 4.0 dongle.
When I connect a DualShock 4 controller only I have no problem.
But I got bluetooth speakers (bt ver 2.1) and when I connect them both, the controller is laggy. I can see in InputMapper that the latency is bad.
What are my options to fix this? Can I get a better dongle? Or are all dongles the same.
I am planning on buying also bluetooth headphones but I want to use the controller and headphones at the same time. I won't buy the headphones otherwise.
https://linustechtips.com/topic/1053140-bluetooth-latency-issues/
