Mining help?
Hey guys, I want to start mining coins but I'm unsure on what to mine(Litecoin, Dogecoin Bitcoin, etc..., what program to use, what pool, how to check how much I have made and how to turn it into real spendable money. I have a R9 290 gpu and a i7 4770k if that is matters..
Some help would be nice. (:
You can mine with your current system but it's more usefull and more performing to mine with a dedicate separate mining rig with more than 1 GPU. However, to try it out you can totally mine with what you have now.
HOW TO MINE
everything is here, just read and understand it
1- Dowload cgminer (I'm using version 3.7.2) and create a .bat file pointing to the executable.
2- Subscribe to a pool of your choice. Depending on what you want to mine and what type of payout you want, you'll choose a pool. You basically don't want to mine anything that's ASIC based. I suggest mining dogecoins on multipool.us.
3- Login to your pool account and create a worker and its password.
4- Go into the HOME or STATS or HELP portion of the site to try and locate the port information (should look like this : -o stratum+tcp://pool1.us.multipool.us:7777 -u username.1 -p x , with username.1 being username (of the account).worker name and -p x , x being worker password)
5- go to https://litecoin.info/Mining_hardware_comparison and locate your hardware. In the 8th column will be the cgminer settings you'll use for startup.
6- Open the .bat file with wordpad and paste the following information :
