FX-8350 hot fix?
Go to solution Solved by Priller,
It was already rolled into an update for Windows 7
Hi guys
I know that these are quite old hot fixes but I've only just discovered them and just wondering if they actually increase performance by a lot? I've heard some good and bad things, those with first hand experience would be helpful :) thanks!
Hot fixes - http://support.microsoft.com/kb/2645594
Edit: this link also works - http://www.techpowerup.com/mobile/158534/new-windows-7-bulldozer-patches-available.html
CPU Intel i7-6700k | Motherboard ASUS Maximus Hero VIII | GPU MSI GTX 970 | RAM 16 GB Corsair Vengeance 3000Mhz | Cooling Noctua NH-D15 | Storage 240GB Crucial M500; 2TB Seagate Barracuda | PSU EVGA 850w | Case Phatek Enthoo Pro M Acrylic
https://linustechtips.com/topic/105268-fx-8350-hot-fix/
Oh really? Is that the dual core optimiser that's on my pc?
https://linustechtips.com/topic/105268-fx-8350-hot-fix/#findComment-1407667
Not sure. I was looking into it and I remember it being said that it was rolled into a Windows update. The hotfix was just for a quick fix until an update rolled out.
Oh ok, and by the way I used to have a 4170, and for some reason there was a program called AMD - dual core optimiser or something and it's still there with my 8350, should I keep it or?
https://linustechtips.com/topic/105268-fx-8350-hot-fix/#findComment-1407686
I would see what it is first and do some research on it to see if you still need it for a program etc.
https://linustechtips.com/topic/105268-fx-8350-hot-fix/#findComment-1407698
Ok thanks, I just can't seem to find much on it hahaha, thanks for the info though!
https://linustechtips.com/topic/105268-fx-8350-hot-fix/#findComment-1407708
