Anyways though, I leave my PC on 24/7, usually in sleep mode or something, just tap the keyboard, type the PIN, and I'm in.
I noticed some lag and got a Storage Spaces notification and I clicked it and 1 of the drives said something, so I did a shut down, but the PC never shut down, the screen went dark after the Windows thing shut down, but I had to manually hold down the power switch, and when I turned the PC back on, I had a black command prompt looking prompt asking me if I wanted to load my OC profile from the bios or enter setup, and after loading my OC profile, I got back into Windows and the drives are not showing up in Disk Management or Storage Spaces.
The drives are the same, each of them being a 4TB Seagate SSHD from a couple of years ago, I have almost never used them, and they have been in my PC for the past 6-12 months.
Case: Dark Base Pro 900 (Black/Orange)
CPU: Ryzen 5900x
CPU Cooler: Noctua NH-D15 (LTT Special Edition)
Graphics Card: RTX 3090 Founders Edition
Motherboard: ASUS ROG Strix B550-F Gaming
RAM: Team T-Force Night Hawk RGB 32GB DDR4 3000 (2 x 16GB)
Storage (Boot): Samsung 990 PRO 2TB NVMe
Storage (Secondary): Samsung 980 PRO 2TB NVMe
Storage (Secondary): Samsung 850 EVO 1TB SATA III
Storage (Secondary): SanDisk Ultra II 960GB SATA III
Storage (Secondary): 2x Seagate 4TB SSHD (yes, really, solid-state hybrid drives in 2023)
PSU: Corsair RM1000x (80+ Gold)
OS: Windows 10 Home
Keyboard: Razer BlackWidow V3 Pro (with Razer Yellows)
Mouse: Razer Viper Ultimate Wireless
Mousemat: Razer Firefly Chroma Mousepad 2016
Headset: Logitech G533 Wireless Headset (still the best)
https://linustechtips.com/topic/1051737-possible-drive-failure/
If you loaded your OC profile in the bios some of your settings might have reset and it might be needed for you to adjust the boot settings/disk drive settings in the bios/uefi.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1051737-possible-drive-failure/#findComment-12455224
I don't know what happened, after doing all sorts of tinkering and breaking one of the plastic clips on my SATA port which I still have to use and still works, just loosely, they work again, so I guess it was just a weird error, but I am moving things from them and separating them right now, they were being used solely for game storage for 4 games, so I guess it isn't that important, and I didn't lose anything.
Any way to fix a broken SATA connector, the little side piece is broken off.
CPU: Ryzen 5900x
OS: Windows 10 Home
https://linustechtips.com/topic/1051737-possible-drive-failure/#findComment-12455313
