1 minute ago, RedDeathOne3 said:
Ok so I have a old Corsair H50 and before I put out money for a new cooler  is it possible to add liquid back into the loop? I'm just trying to revive an old rig for light use so if I don't have to put money into it that would be great. Thanks in advance.
your better off just spending the money on a cheap air cooler like a hyper 212. If the pump is old enough to need fluid its likely on its last legs any how. also once you break the seal Its likely to leak or have more issues down the road.
https://linustechtips.com/topic/1050519-aio-maintenance/#findComment-12445118
idk If I'd get a Hyper 212, that's quite an outdated design.
But a cheap air cooler like an Arctic Freezer would probably be just as good, considering the H50 is a 120mm rad.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1050519-aio-maintenance/#findComment-12445130
They have the new Hyper 212 Black Edition and phantom edition but yes I use the 212 loosely as a generalization
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-rgb-black-edition/.
https://linustechtips.com/topic/1050519-aio-maintenance/#findComment-12445143
eehh, the Arctic Freezer 33 eSports One outperforms the 212 for the same price.
*GPU Test Bench*
https://linustechtips.com/topic/1050519-aio-maintenance/#findComment-12445162
