41 minutes ago, star_pilot475 said:
So my PS4 recently decided that it doesn’t want to start. I researched the topic and supposedly all of my data is now gone. If I buy a case to use the drive as an external drive could I get my save data off of it?
You should be able to directly connect your ps4 drive to your pc
https://linustechtips.com/topic/1050237-ps4-help-needed/#findComment-12442645
2 hours ago, GloomyBoi said:
Has anything new happened? Are you experiencing the same problems?
I pulled the hard drive out, it’s sitting until I can get a drive big enough to clone it. Once I do, I’ll try that, wipe the original drive and pop back in the old one once I clone it back.
I got a ps5 and a pc pretty ballin
https://linustechtips.com/topic/1050237-ps4-help-needed/#findComment-12454463
