My phone has suddenly started not working when connected to any Wi-Fi network. When i'm connected, it says "Internet May Not Be Available".
My phone is a GS9+ and i'm on version G965U1ES3CSAA / G965U1OYM3CSAA / G965U1ES3CSAA with security patch level February 1, 2019.
I've tried the following:
- Restarted the router (i'm on Xfinity)
- Restarted the phone
- Forgot the network, and reconnected.
- Reset network settings
I was suggested that my IP settings might not be matching what my router says it is or something like that. I'm not sure. All I know is I do not want to factory reset my phone at all.
the sky is up
https://linustechtips.com/topic/1049366-phone-wifi-issues/
40 minutes ago, .Ocean said:
Make sure your phone is set to DHCP IP or to automatically get an IP. On top of that make sure your access point is behaving properly
It is on DHCP, nothing. Access point on my mobile data is fine. No improvements so far.
the sky is up
https://linustechtips.com/topic/1049366-phone-wifi-issues/#findComment-12435847
