Hello! i've been looking into buying a pair of "truly wireless" earbuds but i dont know what to buy, there is a bunch of different ones so i would appreciate som guidance.. they will be used when going to school and for working out so any suggestions? i have an iphone 8 if that helps at all
Watches and computers
https://linustechtips.com/topic/1049218-true-wireless-earbuds/
34 minutes ago, star_pilot475 said:
never heard of the brand, is it any good?
https://linustechtips.com/topic/1049218-true-wireless-earbuds/#findComment-12434576
The only ones worth buying are airpods, Sennheiser true wireless, or Master & Dynamic MW07
Airpods for lower price and most convenience
Master & Dynamic MW07 for audio quality
Sennheisers for slightly lesser audio quality but better overall functionality and convenience than the MW07
https://linustechtips.com/topic/1049218-true-wireless-earbuds/#findComment-12435171
Jaybird freedom
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1049218-true-wireless-earbuds/#findComment-12435250
14 hours ago, Slumberjack said:
Jaybird freedoms aren't true wireless fyi, they have the goofy connector wire
Oops, meant the Run
21 hours ago, smiles rising said:
Do you have them yourself?
No, but supposedly not bad
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1049218-true-wireless-earbuds/#findComment-12438692
1 hour ago, food158 said:
Oops, meant the Run
For that kind of money, IMO the airpods are better for iphone, and the jabra 65t is better for android
Bose Soundsport Free is also a good one for either platform for a bit more money
But I still maintain the sennheiser true or the master & dynamic mw07 are best bang for buck, even at the steep price
https://linustechtips.com/topic/1049218-true-wireless-earbuds/#findComment-12438794
Aren't they cheaper than the airpods?
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/1049218-true-wireless-earbuds/#findComment-12442456
It's like a $30 difference, which if that $30 really cuts into your budget, then sure, but it's a pretty small stretch for the convenience. Functionally the airpods are the best damn pair of true wireless buds out there by miles, they just lack in terms of sound quality and the fit isn't quite as sure as many workout focused buds, provided you plan to workout with them.
https://linustechtips.com/topic/1049218-true-wireless-earbuds/#findComment-12462065
