RGB Lights Question
11 minutes ago, STEAL7HY said:Hello I was wanting to use this case https://www.newegg.com/Product/Product.aspx?Item=N82E16811119330
This AIO Cooler https://www.newegg.com/Product/Product.aspx?Item=2YM-0004-00015
This light strip https://www.newegg.com/Product/Product.aspx?Item=N82E16811999390
And three of the spliters https://www.newegg.com/Product/Product.aspx?Item=N82E16812229001
On this Motherboard https://www.newegg.com/Product/Product.aspx?Item=N82E16813157800
Will this work with my attached layout or will I need to do something different I want them to be the same color (White) Thank you for your time
With so many components you will most likely overload your RGB header as it has a max amperage of usually around 2-3amps so you will need to check the total load of all the components. If that is so you will want to use a power RGB splitter such as this instead which will take an external 12V.
http://www.xs-pc.com/fans-radiator-accessories/8-way-4pin-12v-rgb-splitter-hub-sata-powered-black
-Moved to Modding section-
