I recently built my first PC and i'm trying to format the hard drive I got for it but when I open the disk manager tab I don't receive the notification prompting me to do initialize, what can I do to fix this?  (The hard drive does show up in the bios)
Thanks in advance!
https://linustechtips.com/topic/1047929-hard-drive-help/
Thanks in advance!
usually its a failed hdd but you can do some checks to make sure
1.removing and replugging the cables and trying diif sata ports.
2.u can dwld ubuntu into a usb and boot it.then try to format it.
https://linustechtips.com/topic/1047929-hard-drive-help/#findComment-12423298
