I'm going to buy vega 64 gigabyte card tomorrow i have a G550M cooler master PSU atm to use with my RX 480 4GB but need a better PSU which one of these two PSU's would be enough to run the 64? I'm keeping my system cooler master and gigabyte themed. Thanks
Option 1:
 https://www.amazon.co.uk/Cooler-Master-Fully-Modular-RS650-AFBAG1-UK/dp/B0118FI5AM/ref=sr_1_1?ie=UTF8&qid=1553461171&sr=8-1&keywords=Cooler+master+650w
Option 2: https://www.amazon.co.uk/Cooler-Master-MasterWatt-Semi-Fanless-MPX-6501-AMAAB-UK/dp/B07624NCL9/ref=sr_1_2?ie=UTF8&qid=1553461171&sr=8-2&keywords=Cooler+master+650w
https://linustechtips.com/topic/1047825-psu-upgrade-help/
The masterwatt is much cheaper for a reason, not that it's bad but it's their lower tier product. Either would be more than enough though, an improvement over your current unit.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1047825-psu-upgrade-help/#findComment-12422387
I'm pretty sure there's better psu's than that for the price, surely. V650 is a good psu but there's better value options.
For example, Corsair RMx is a newer series, and cheaper:
https://uk.pcpartpicker.com/product/2HbwrH/corsair-rmx-2018-650w-80-gold-certified-fully-modular-atx-power-supply-cp-9020178-na
Seasonic has a good 650w one for better:
https://uk.pcpartpicker.com/product/WrNypg/seasonic-focus-plus-gold-650w-80-gold-certified-fully-modular-atx-power-supply-ssr-650fx
There's probably one or two more better for the price if you search for them.
https://linustechtips.com/topic/1047825-psu-upgrade-help/#findComment-12422412
Option 1:
V-Series, hands down.
Though I do not know, if it will work because I haven't tested it. But I don't see a reason for it not to.
Other ALternatives are be quiet Straight Power 11, Bitfenix Whisper M (tested positive).
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1047825-psu-upgrade-help/#findComment-12422692
Not that much, Cooler Master V-Series is a very good unit.
Not a good idea with VEGA.
They have Problems with it and admitted it.
https://linustechtips.com/topic/1047825-psu-upgrade-help/#findComment-12422694
10 minutes ago, hello_there_123 said:
naa...
https://www.tweakpc.de/hardware/tests/netzteile/corsair_tx550m/s08.php
Fan noise is a bit on the high side and he has the money, so he can get a decent, quieter PSU...
https://linustechtips.com/topic/1047825-psu-upgrade-help/#findComment-12422725
