I Overclocked my Asus ROG RTX 2060 in Asus GPU Tweak and then the screen went pink and green.
And I can see that everybody else have higher FPS than me with the same GPU.
In CS:GO I run 50-180 And the other run CS:GO from 200-350 FPS!?!??!
And this is also in other games!
PLZ help!!!
https://linustechtips.com/topic/1046876-fps-drop-after-overclocking/
PLZ help!!!
What's your cpu. The pink and green means it's a unstable overclock. It's probably factory overclocked a lot and will need more voltage to get a higher clock. CS:GO high framerates don't just come from a fast gpu but a fast, overcloked intel cpu. AMD cpu's don't have as high single core speed and intel cpu's are a little better optimized for it.
Discord: Skyline#0820
Literally an idiot, don't listen to me.
Main computer: i5-4690k 4.3GHz, Noctua NH-D15, Nitro+ RX 580 SE, 16GB Corsair Vengeance, Samsung 840 series 128GB Crucial MX500 2TB, WD Purple 3TB, EVGA 600w, Dell s2240m 1080p 60hz, Corsair K70 Cherry MX Blue, Logitech G502 Hero.
Asus GU501gm
then your overclock is a failure and probably doing a lot of things it shouldn't do, that's why performance drops and it goes pink and green
Desktop benching:
But I Turned off the overclock and it is still not giving enough FPS. But can you guys help me fix it??
I have an Intel Core i5 7400
first thing to do is not make your problem seem serious, because it isn't.
Is the GPU frequency locked to 1350MHz when gaming?
with this low frequency CPU, dont expect more than 200fps. I dont think it can even go to 150fps because of the limited single core performance, but not sure.
Desktop benching:
