Hi!
so i bought 4x4 adata xpg ram 3000mhz from someone . he showed me that every stick was showing and i assumed everything was ok.
when i installed all of those sticks on my motherboard the pc actually turned on ,but the problem is that sometimes it freezes . So i tested all of them individually and one had problems,  it can boot but if i open anything like opera or chrome it immediately crashes.
i get that this stick has problems but is there any chance i can fix that? or maybe some computer fixing company , or is it just unusable?
this is my other parts
ryzen 5 1600
gigabyte ax x370 gaming 5
evga 450 80 bronze
gigabyte gtx 1060 3gb oc 1 fan
https://linustechtips.com/topic/1046807-ram-problem/
Yes, i bet switching to Intel CPU will fix the issue
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1046807-ram-problem/#findComment-12413989
