hi i have been using b450-f asus board pair with 2700x and month ago i bought tridentz 32 gig ram(3000mhz)
but is running on 2733mhz if i set any highier then this it will just go back to default which is 2133mhz
i didnt change anything.it says on the packet (cL15 1.35v)..so i undersatnd is to get to 3000mhz i need have my latency set to 15 with the temp 1.35v
its runs stable on 2700mhz.but it shows latency 16.0 in corsair icue space is any way i can get 3000mhz ..hope u guy's understand it's a bit confused .
done v bit research still nothing..
 spec are.. ASUS ROG STRIX B450-F Motherboard
             AMD Ryzen 7 2700x processor
            G.Skill Trident Z RGB 32GB (4x 8GB) 3000MHz DDR4
temp are 30 on ide    thanks
https://linustechtips.com/topic/1046738-help-with-ram-setting-please/
