Hello everybody.
I'm building a new setup, and I want some help picking parts.
The computer will be used for editing, gaming, streaming, and recording.
Should I get a 2080 ti or 2x 1080 ti? And which CPU should I get?
Some of the current parts
Link: pcpartpicker.com/list/CFxJ3b
Thanks!
https://linustechtips.com/topic/1046530-need-help/
3 minutes ago, Mikkelius said:
Hello everybody.
Thanks!
I would get the 2080ti as you won't have to deal with buggy sli unless you're up to the task. It really matters up to you whether the i7 or i9 is good enough for you. Also 500gb is not enough storage for a PC like that. Your also gonna need a cooler
https://linustechtips.com/topic/1046530-need-help/#findComment-12411146
1. what resolution and fps
also what games
budget?
ive heard that the strix z390 boards have bad vrams and you should go with either aorus or asrock
2. 2080ti cause sli is weird and doesnt always work well
dont get the founders edition card get the cheapest triple fan you can
3. This is a high end system nzct h500 isnt great for airflow instead go with like a meshifyc
4. you can get the ram for a cheaper price
Type Item Price
Memory G.Skill - Ripjaws V Series 16 GB (1 x 16 GB) DDR4-3200 Memory $100.98 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total $201.96
  Generated by PCPartPicker 2019-03-20 19:54 EDT-0400
https://linustechtips.com/topic/1046530-need-help/#findComment-12411856
also what games
budget?
Type Item Price
  Total $201.96
Budget: 2800$~
Resolution: 1080p
Could you recommend a specific case? :) (Red could be nice)
Where can I get the ram cheaper? :P
https://linustechtips.com/topic/1046530-need-help/#findComment-12412564
