Fan controller power ?
Go to solution Solved by rjshield,
It's so it doesn't use up a connector on the power supply. For example if your power supply had only one molex connector you could still use this fan controller and another device.
In short leave it unplugged.
Hey Peeps,
I'm almost finished with my gaming pc build, and bought a fan controller to power all the fans.
So I bought this akasa fan controller. http://www.akasa.co.uk/update.php?tpl=product/product.detail.tpl&no=181&type=Accessories&type_sub=Function%20panel&model=AK-FC-08BKV2#
After installing it, It needs a Molex to power the controller.
Then there is this.......
What do I do with the other plug? Does it give me extra voltage?
Thanks guys, looking forward to your reply.
https://linustechtips.com/topic/104640-fan-controller-power/
Build Log: Monochrome
CPU: Intel Core i5-4670K | Motherboard: Gigabyte GA-Z87MX-D3H | Graphics Card: Asus HD 7970 DirectCU II | RAM: Corsair Vengeance Pro 8GB | PSU: Corsair CXM 600 | Storage: OCZ Vertex 4 128GB,2 Seagate Baracuda 3TB | Case: Corsair 350D Window
https://linustechtips.com/topic/104640-fan-controller-power/#findComment-1399366
If it works, don't worry about it.
Like a ninja sir.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/104640-fan-controller-power/#findComment-1399370
Like a ninja sir.
  :ph34r:  :ph34r:  :ph34r: just trying to help since it's solved   :ph34r: :ph34r:  :ph34r:
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/104640-fan-controller-power/#findComment-1399412
that is just an extension of what you used
source >> i had to figure that out few weeks ago  :)
ExSystems
https://linustechtips.com/topic/104640-fan-controller-power/#findComment-1399422
Thanks a lot !
Thanks to everyone who replied.
https://linustechtips.com/topic/104640-fan-controller-power/#findComment-1399666
